Display MSTP MSTI Information
Display MSTP MSTI information to ensure the feature is configured correctly for your network.
Display MSTI information:
Switch:1> show spanning-tree mstp msti config 62 =========================================================================== MSTP Instance Status =========================================================================== Instance Id : 62 Msti Bridge Regional Root : 80:00:00:15:e8:9e:10:01 Msti Bridge Priority : 32768 (0x8000) Msti Root Cost : 0 Msti Root Port : cpp Msti Instance Vlan Mapped : Msti Instance Vlan Mapped2k : Msti Instance Vlan Mapped3k : Msti Instance Vlan Mapped4k : 4000
Switch(config)# show spanning-tree mstp msti port statistics 1/1 =============================================================================== MSTP Instance-specific Per-Port Statistics =============================================================================== Port Number : 1/1 Instance Id : 1 Msti Port Fwd Transitions : 0 Msti Port Received BPDUs : 0 Msti Port Transmitted BPDUs : 0 Msti Port Invalid BPDUs Rcvd : 0
Use the data in the following table to use the show spanning-tree mstp msti command.
Variable |
Value |
config [<1-63>] |
Shows the configuration for one or all MSTP instance IDs. |
port |
Shows the configuration, role, or statistics information of a MSTP port.
